Search the forum,
Discuss Help, shower cable overheating in the UK Electrical Forum area at ElectriciansForums.net
so--to summarise so far
the correct torque of a 10mm shower cable in a neutral termination is determined by using an impact screwdriver or battery drill
and not some kind of torque wrench as has been mentioned ?
Jamie I was jesting. :smilewinkgrin:
There was another thread on here recently, with pics of an 18volt impact driver doing up a consumer unit.
I use an old yankee screwdriver yee haaa !!!!
you don't need any fancy tools, you will know when it's tight by only using a screwdriver, do the tug test afterwards
ah :redface:, but they are very good, maybe the 18v is a bit much, but the smaller 10.8 is perfect imo, Im not on about going nuts and holding the trigger so there's no head left on the screw, but just to do the majority of the work then check with screwdriver after, worked well for the past year anyway
i know jamie was jesting
i still want to know the tourque setting for the neutral term though and a pic maybye of said tool
...Not the torque screwdriver debate again? ...just practice,practice and use your senses...torque limiting drivers do not take into account other factors. This is part of the reason some structural steel work and other critical assembled items such as cylinder heads,steering components etc are "angle rated" from a base torque or position. Next we'll be using "acceptable impact force interfaces" fitted to the end of bolsters,so we know we are hitting them hard enough...lets give the trainees of tomorrow something to add to experience....confidence. Then,when they have BOTH,they can blow their wages on any clicky tool-box ornaments they fancy :stooge_curly:
New posts
Reply to Help, shower cable overheating in the UK Electrical Forum area at ElectriciansForums.net
Went back it a house after they upgraded shower to a 9.8kw, pulling 40a constant. We had wired it with 10sq and 40a RCBO. 10sq Neutral cable...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
