Discuss Help understanding AC motor diagram please in the Auto Electrician Forum area at ElectriciansForums.net
Screenshot_2021-12-24-06-25-47-778_com.ebay.mobile.jpghi can I anyone help me understand wiring one of these l, also what capacitor needed. I want to use with a speed controller. To be used on DIY reeling machine Any other tips thanks in advance.
TL;DR
Understanding motor wiring diagram help!
Most speed controllers are designed to work with 3 phase motors
even if you are using a single phase supply.
what you have there is a fixed speed single phase motor.
it may be possible to use it but you are making life really hard for your self.
Thanks for replying
Hi I was told by a motor supplier that single phase motors were easier to control speed. so now even more confused.
If you want high torque at low speed, a DC motor is likely to give you the best speed control as it gives 100% rated torque from zero Rpm
does this motor supplier not recommend or sell a controller that goes with this motor they sold you?
View attachment 93341hi can I anyone help me understand wiring one of these l, also what capacitor needed. I want to use with a speed controller. To be used on DIY reeling machine Any other tips thanks in advance.
"also what capacitor needed" -> 6uF 440v
To change the speed of this motor you would change the supply frequency, however the motor has been designed for 50Hz only!
You might get away with +/- 5%
Any more than that and you will overheat quickly
Reply to Help understanding AC motor diagram please in the Auto Electrician Forum area at ElectriciansForums.net
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
Hello right off the bat I'm a novice with a little better understanding than most(father was a electrician) but I am not an electrician. I'm...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Hello, novice diyer here, but trying to learn more about electrical. I have done some basic wiring but that's about it. I have one of those...
