Discuss Help with choice of fittings in the Electrical Tools and Products area at ElectriciansForums.net
Morning chaps!
Having now assisted several local electricians on domestic 1st and 2nd fix, I have some questions for the forum :)
What manufacturer/range of fittings would you guys recommend that provide a good balance between size of range, quality, price and ease of installation? The guys I’ve been working for have quite different opinions on manufacturers, depending on ease of install vs quality and price.
I already have some preferences (Hager sockets for example), but would be interested to hear opinions from multiple sources, especially for the harder to fit stuff like fused spurs (found that a fused spur off a ring with the three cables can be difficult to fit!) and cooker connection units and cooker switches (10mm is hard to terminate!)
Thanks in advance, and apologies if this has been asked before but I can’t find anything on the search.
Darren
I use Hager for my white plastic range, have done for years now. Click have a few very good quality ranges, and Schneider lisse is also worth a mention.
Often the ease of fitting is more to do with the depth of box your using.
Also some careful planning as to the location of the item, often just moving it a couple of inches away from where you had initially thought can make life so much easier.
Anything but lap is usually fine. As long as the fuse spurs don't have stupid terminals with the neutral at the bottom and they are all centred they are ok
Fair point James, although most of the problems I find with fitting are due to poor placement of the terminals (usually I assume as it makes it cheaper!). For example, downlights with feed in and feed out terminals, where the order goes E-E-L-N-L-N or E-L-N-E-L-N. When all flat T&E I've used goes L-E-N (or N-E-L of course hehe)
Fused spurs with a mix of supply and load terminals all over the place is really annoying! Supply and load sides split equally is so much simpler :)
I know right? I hate it when you have to concentrate on the job!
I use Hamilton Verve - bit of quality, good range throughout and easy on the eye. The posh range are quite expensive though. Moulded white is very affordable.
Hager were my faves for a long while - gorgeous to look at. Selling point for me!
What ever happened to Tenby ?
Used to see Tenby all the time on council rewires and new builds in from 80s and 90s
Brought out by Legrand who phased it out very 80's chunky but had nice large bellmouth terminals you could get 3x6mm into double sockets, used to like Contactum for this reason but its not stocked anywhere. Around here Deta and Hager c.u's are stocked a lot as used by the developers.
Reply to Help with choice of fittings in the Electrical Tools and Products area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Electrical2Go - Save Time Installing Cables with Super Rod At Electrical2Go, we're constantly striving to bring you the latest and most...
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
Hi Guys I'm not a Hager user so hence the question. I've been asked to wire in lights and a fan etc for a bathroom for a mate of mine who's a...
