Discuss Help with my house wiring. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
can you explain more fully what you are trying to do
don't know what you mean by " circuit box ". think sintra's comment most appropriate. if you are not sure what you are doing, get a competent electrician. you could end up killing somebody
How do replace a circuit in a circuit box?
With a fair whack of time in a classroom getting educated on the subject,foolowed by practical experience learning on the job, until the time comes when you are confident that you can do the job,then when you have done a few more to get experience, the job could be tackled without supervision
Reply to Help with my house wiring. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, I’ve purchased a Ring Spotlight camera and decided to remove the old spotlight that’s currently installed on the house we recently...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
