It may be my eyes, but i cant see no neutral cables going into the RCBO??
Precisely and this has been noted previously, I suspect this is why the OP has disappeared and solved the problem.
As the Lewden RCBO terminals do not look like the same format as any I have seen in the last few years, but match the others in the CU, I'd say that it is a load of -------s that anyone brought that with them to do the job.
No electrician turned up to this job at all, whether the OP did it or not.
