Discuss Hive system playing up any ideas? in the Central Heating Systems area at ElectriciansForums.net
T
The Ghost
So my son has a hive controller and while it appears to say system is on the boiler does not switch on. Sometime later, maybe an hour the boiler switches on. Any ideas ? It is a potterton boiler quite old and the hive has been tacked on, perhaps wrongly. Anyone in the Farnham Surrey area that can check it out ?
Hi @Wilko thanks for reply. So I think it is sporadic and unpredictable doing strange things here and there. They have just moved in a week or so ago and finding out about the house so all is not clear yet. Sorry about delay just driven back from Surrey.
@Wilko has stepped into the breach @davesparks thanks a lot though. I do like the idea of motorised valve sticking/intermittently operating. @handyspark, I did say to my Son that there could be an old stat that is not disconnected given the way the wiring is in there. He was adamant it was all disconnected, same as when I checked the supply at the boiler and it was there he was adamant no power was getting through, hey ho!
The hives ive had being intermittent, were due to connection issues from receiver, as it was too close to the boiler (or being screened by multiple walls to the hub) poor signal, although it looked healthy.
The other one was the receiver had been mounted onto the old controller plate, and didnt get a decent pin connection. I tend to use the plate that it comes with.
I hope you have resolved this now.
Stay lucky
Reply to Hive system playing up any ideas? in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi, I’d really appreciate some advice or suggestions as to what could be causing an ongoing issue I have with my RCD tripping. My RCD trips when...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
I had a problem a couple of days ago with my boiler shutting down due to too high temperature difference between the input and output, which...
