Discuss Hole saw recommendations in the Electrical Tools and Products area at ElectriciansForums.net
all thoseback boxcutters are useless on anything but plasterboard. and even then they take 10 x as long as a padsaw.
If you look at it theres no way that can actually even work ;)
I was thinking the same but then I found this on youtube:
Gtranted, this one is a bit of a different design then the earlier one but... seems to work. Althought the bit about 'not hurting the technicians' at the very end is hilariouse XD
.....it's only a matter of a couple more posts,before you're gonna get the "hammer & bolster" advice... :neutral:
Those box shaped cutters look absolute tosh. It takes about 20 seconds to cut one out with a straight multitool blade. How many seconds do you need to save per box, is the job that time critical, are you doing that many boxes it would make a difference ?
Using multitool blades in plasterboard ruins them pretty quickly anyway so you're going to need a constant supply if doing a lot with them. You'll need a single and a double which is about £20 combined. I use one of my sub £2 wood bits that is on the way out. Much cheaper.
Sure, strictly plasterboards usage.
But if already on the topic, any tools or technique you would recommend for brickwork?
for brick, i stitch drill with a 7mm or 8mm sds bit, then whack in a sds scutch chisel.
Reply to Hole saw recommendations in the Electrical Tools and Products area at ElectriciansForums.net
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Not my department in our house, but what are everyone’s go-to brands for washing machine and tumble dryers? Both of ours have decided to call it...
A friend of mine is looking to have an electric shower fitted and has floorboards up already (mostly, long story). Anyway there is a run of 2.5mm...
I’m looking to buy a hole saw set for drilling into wood, metal and plastic. Any recommendations please?
5K
