B
Buzz1980
Hi all
Question regarding the amount of cables through holes in joists. Is there a set amount that you should stick to, or does it not matter how many cables are through a joist hole. As long as there is movement in the cables, finger gaps side of cables, reason i asked as seen about 8/9 cables go through a 32mm hole but there was still movement? Thanks in advance
