Discuss Holes through joists in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all
Question regarding the amount of cables through holes in joists. Is there a set amount that you should stick to, or does it not matter how many cables are through a joist hole. As long as there is movement in the cables, finger gaps side of cables, reason i asked as seen about 8/9 cables go through a 32mm hole but there was still movement? Thanks in advance
Reply to Holes through joists in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
Hi everyone, I'm hoping someone here can help. I recently did some carpentry work for a new customer and I noticed their electrician had just...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
