Discuss House water pump keeps needing a reset in the DIY Electrical Advice area at ElectriciansForums.net
twocans
Hi. I have a single phase water pump which supplies our house. It frequently cuts out and needs to be reset (on pump itself). Because of our location (rural Spain) I suspect it is erratic voltage supply. Is there a power regulator I can use in between pump & outlet to overcome this?
possibley a UPS, the better ones have a double conversion that takes whatever input voltage is available and converts it to dc voltage.
this is then converted into an ac sinewave output of the correct voltage regardless of the input voltage (within limits)
Thanks James. The pump
Hi James. Thanks for your reply. I would appreciate picking your brains again, before buying a UPS. The attached pictures xhow the pump, what size UPS would be best? Many Thanks.
i would be looking at a 2000VA unit also known as 2KVA
Reply to House water pump keeps needing a reset in the DIY Electrical Advice area at ElectriciansForums.net
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Dear Forum, I recently joined this forum, and writing for the first time. I like DIY activities, both for hobbies both to fix and repair stuff in...
The Pump House for my Water Well is located way out in a field about 350 Ft from the house. It is wired with Romex 14-2 with a Ground. I have 2...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
