N
nicebutdim
The problem you highlight is there nothing to stop anyone calling themselves an electrician regardless of what level of study or qualification they have achieved, you are critical of electricians turning out appalling work but have you ever checked what qualification or level of training they have
All the comments around training only ever seem to refer to how easy it is to carry out an installation with no mention of faultfinding or identifying potential issues with meter readings which can be a critical part of an EICR
All of this reminds me of a guy I got chatting to at one of the shows he had done the short courses and been asked by a customer to change an outside light but couldn't find where to isolate it so he recommended that the customer got a proper electrician in to sort it
Look at the electrical industry from the perspective of a domestic customer and you've pretty much nailed the problem...
Joe Bloggs comes home to find his downstairs lights have gone out and he reaches for the yellow pages (more likely google these days). He has no concept of the various levels to which any of the electricians he calls might be qualified to and, quite frankly, nor should he. It's reasonable for that consumer to assume that anyone advertising their services as an electrician should be able to find the fault and fix it, but sadly we know that fault finding and repair can take many different forms and can be carried out to a wide range of standards - that's not casting aspersions on any particular people, it's a simple and sad fact of life. If the average householder was to ask what level an electrician was qualified to, the answer would mean nothing to them.
I'll give you some examples from personal experience:
1. My parents paid to have some electrical work carried out in the 80s by a time served elctrician. The cables were pulled in so roughly that I subsequently found (when doing unrelated work) that over 10' of continuous outer sheath was torn, with line and neutral insulation damaged in several sections and conductors exposed to any rodents that might happen upon them. This was a guy who served his time in the 70s and had a decade of domestic and commercial experience under his belt.
2. New build house with split load board and one RCD begins to trip after a year. I wanted to know what was causing this fault and have it repaired, so my first port of call was the electrician who wired the place. I was more than happy with his previous work, but the guy is very busy and hard to get hold of. During a brief phone conversation he felt the RCD was the least likely cause and that the most likely the fault was caused when I'd changed some accessories (at my other half's insistence) to decorative and he promised to call and do some testing. I was pretty certain that the change of accessories hadn't been the cause of this issue, but would have been happy to be proven wrong. Unfortunately the electrician didn't turn up and also failed to show on a subsequently arranged day - 18 months later I still haven't heard from him. I was still stuck with an RCD taking out half the board and no means of heating a drop of water, as the boiler was on one of the affected circuits, and a wife and child who were less than impressed with intermittent hot water when showering. I tried finding local electricians through google and spoke to quite a number. Many were busy with contract work and were quoting 6-8 weeks before they could fit me in, while most others were happy to come reasonably quickly, but talked of replacing the RCD and shied away when I asked if they could test to find the actual cause. By this stage constant resetting of the RCD had meant that it was nigh on impossible to reset and I was no closer to finding a local electrician who was competent in testing. In the end I reluctantly stuck in a new RCD in the hope that it might buy some time and haven't had any issues since - was the RCD the cause of my problem or is something else still underlying, but not causing enough earth leakage to trip? I've no idea, but hopefully by this stage you get the point I'm making.
Getting back to the point on which people have argued; what would make me or any other aspiring electrician who chooses the short course route less than competent? Someone who wants to blaze through in the sortest time possible and learn the bare minimum is no different from an apprentice who puts in the bare minimum of effort and scrapes through their apprenticeship. There's no reason why someone who goes down the short course route wouldn't seek to gain years of experience alongside a competent electrician and only undertake work which is well within their abilities.
The term "missed the bus" was used earlier to dismiss another member whose opinion was not appreciated. I'm not offended that someone wished to defend their trade, but do feel that comment was unwarranted. At what point does a person miss the electrical bus? The commentator in question clearly felt that anyone entering the industry as an adult fits the bill, but what about apprentices who have to resit their GCSE english or mathematics? Should they be thrown off the bus? Maybe those apprentices who fail modules of their training shouldn't be given the chance to resit them.
I don't want to spend 6 weeks training and then bust out my tools in unsuspecting households. I want to get into an industry that is particularly difficult to enter as an adult and, unfortunately, the only route available to me is through distance learning. My plan is to study hard and get a good grounding in theory, then find work as an electrician's mate to gain my NVQ and continue in that vein to gain good experience. I accept the fact that some electricians will regard my route into the industry as less acceptable than their apprenticeship, but I can live with that and have no intention of leaving work behind me that anyone can find fault with. There are many time served electricians who work to the highest standard, but the fact remains that a significant number do not. If someone is keen to learn and wants to work, they'll always have an advantage over those who want to do the bare minimum and that applies regardless of the route taken in to the industry. Maybe my opinions will be unpopular or unwelcome, but there's no harm in considering more than one side of a discussion.
