Discuss How much power will a resistor rated at 1/2 w...? in the Australia area at ElectriciansForums.net
T
turbomen
How much power (in mW) will a 680W resistor rated at ½ W dissipate when it conducts a current of 15 mA?
Could you tell me how can you get the answer?
ressistance is measured in ohms to have the rating in W you must already know the voltage and if that is the case and this is the only ressistor in the circuit then you already know how much will be dissapted?
so your answer is 0.680000mW
Thank you for your kind reply. But it is a multiple choice question: the answer can be 4.0 mW, 10.2 mW, 153.0 mW, 432.5 mW or 500.0 mW.
Reply to How much power will a resistor rated at 1/2 w...? in the Australia area at ElectriciansForums.net
I am currently making a scaled model display that uses 16 LED in a series and I would like to wire it up to be on one switch, so I need a single...
I have an 5kW inverter and 48V Lithium battery with inbuilt BMS. As you would be aware, when inverter gets battery power, immediately the...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Hi there I have a few questions related to the power ratings of certain devices and how this interplays with the fuse. The reason I am asking...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
