Discuss How to find out where conduit goes? in the UK Electrical Forum area at ElectriciansForums.net
R
RadoXX
Hello everybody! I have a question regarding domestic wiring, i live in block of flats, in my flat i have tv socket which has 2 tv cables coming out from 2 conduits.I have tried to pull them out, and they seems to be stuck somewhere.Could anybody tell me how to find out where does this cable ends and what is the best method to find out where conduit has end?
Many thanks!
Ends at a Arial!
But i guess you are all shairing the same airal for cheapness so will be some splitter some were
did wonder if you ground a TV Arial connection would it ground everyones in the flat..
if thats your own antenna then it may go to antenna around on the wall or balcony . if no antenna to be seen then it will be a communal system, a service room/cupboard somewhere with a splitter/bootster/whatever installed feeding every flat. ask the caretakers or buidling management people.
Coax tends to be just tacked on the outer wall .. bit shocked its in conduit...
Dont know if i will be slapped for suggesting this.. but could Pee down the conduit and FOLLOW THE YELLOW RIVER
im not sure what the great intrest is..
Do you have CABLE TV!!! if you do then it leads to a green box some were
Or Satalight Dish!
Reply to How to find out where conduit goes? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
