Mar 30, 2019
Marnhull, Dorset
I have a 7 year old integrated Neff K42 fridge freezer and I need to replace a couple of the attached kitchen cabinet doors hinges. In order to do so I need to remove the appliance from the casing but cannot figure out how to do it.
I have removed all of the visible screws on the fridge/freezer surround including one securing the freezer to the bottom of the carcase and assumed I would then be able to pull it out but it's stuck firm at the bottom.
Any ideas?
Normally just a bracket screwed into the carcass top and bottom.
Likely rubber feet on it, so might just be sticking as you try to slide it out.
It’s a bit of a faff getting it all back together… to get the cupboard doors to open with fridge doors.
Welcome to the forum :) Did you manage to sort out your issue?
Reactions: DPG
Mike Collard,
Lou,
