Afternoon All,
DIY'er here, Just wanted to run through something which I'm pretty sure is simple but, I just want some claification.
I have some electric wall heaters that have a fused switch on the wall.
I have taken one down as I no longer want it in the room it is in. (obviously with power off etc)
I wanted to replace the electrical switch with a "blank face plate" so the heater can easily be reinstated later if desired.
I picked up one of these https://www.arlec.co.uk/product/connection-unit-20a/ (hopefully correct) - see attached for reverse also
Is it the case that I would have to just put the "live" wires in the left 2 screw connections and the neutral in the right 2 screw connections and attached the single earth cable to one of the others?
Or do i need to put wires together in the screw connectors? Or would I require something else and just ignore what is on the back of the new face plate?
Apologies if this a dumb question,
Cheers,
Richard
Cheers,
Richard
