Currently reading:
How to test a ceiling lights with a plug socket
Discuss How to test a ceiling lights with a plug socket in the UK Electrical Forum area at ElectriciansForums.net
Hi guys
Please don't kill me. I am not an electrician and this is possibly the very simplest of questions you will read today.
I got a custom light fitting created for me and I wanted to test it without having to get it installed on the ceiling first. There are a few bulb options and I wanted to see which bulb would look best on there which is why I wanted to test it.
I took the wires and put them into a UK plug, and put it into the socket. It doesn't work. Can someone please guide me on how I can test this? Is there anything additional I need to do with the wires for it to work with a plug socket?
Hi guys
Fuse blown? a picture might throw some light on the problem, sorry for the pun.
best use a BS1363 plug.
shopping
not a
Have you tried the bulb in a different light to make sure it works?
Yes I have a number of bulbs and a number of these lights. I have tested a couple of lights with different bulbs, but its not working.
I suspect I am not doing it correctly. Do we need something additional in the circuit for the light to work? Like those lamp switches for eg?
Eg:
Light fitting with g9 bulb --- > Lamp switch ---> UK Plug ---> Plug socket
Currently, I have:
Light fitting with g9 bulb ---> UK Plug --> Plug socket
Eg:
Currently, I have:
You won’t need anything more than a correctly fitted plug to make it work.
ere we go again...bulb/lamp....did edison invent the light lamp? did florence nightingale carry a lamp?
You need a two probe voltage tester, or a multimeter to test this and find out where the fault is.
Do you have a multimeter? If not, get yourself down to Maplin before it closes. There will be some going cheap..
Reply to How to test a ceiling lights with a plug socket in the UK Electrical Forum area at ElectriciansForums.net
