Hi should of explained better in first post the old connection switch has been used for years as an on off switch for outside security light with no probs just done up the kitchen and wanted a better looking switch hence the new one just need to know can it be wired up to do the same job thanks
It appears as though the original switch is supplied in 2.5mm cable, possibly coming from the socket circuit rather than lighting.
If this was the case, it would still need a fuse before going to the outside light and reducing the wire size to 1.5mm as it appears to do.
So, no. If I’m right in my guesswork.. you can’t just replace the switch/ fuse with a normal light switch.
The terminals on the new switch, just for information…
Com…. Common. This would be the supply.
1way…. To be used as a single switch
2way…. Used in conjunction with 1way for 2 way switching. (1 light controlled by 2 switches).
Loop…. Just a dummy terminal. Has no connection to the workings of the switch at all. Could put a neutral joint safely there.
