Spudnik
Hi chaps,
Just a quickie.
Anyone see any reason why i couldnt run the boiler & immersion of one 20A radial?
My thinking is, that if the boiler doesnt work, then it wont be drawing any juice, which leaves it available for the immersion.
Anyone see anything wrong with that?
Ta.
We used to do it like that all the time for our local council up until a couple of years ago, now they just dont fit immersion heaters.
I have no problem with it at all, 1 20A switch for immersion & 1 FCU for the boiler.
The only drawback i can see from connecting immersion and boiler to one circuit is that if you get a fault on the wiring of that circuit then it's cold showers all round.
i wouldn't normally combine them for the same reason
the DP switch would normally clear a fault on the immersion side
but a fault on the heating might keep the immersion out of action if it's rcd'd
Well it's a very common occurance.
Ideally a circuit for each is best but that wasn't what the question was. On a lot of occasions an immersion circuit will already be in place and if for whatever resason an additional circuit cannot be installed then technically and regs wise there is no reason why an SFS cannot be fixed to that circuit.
Persoanl preferences are just that.
Spudnik,
davelerave,
