Right I see , its my fault its turned into a farce is it. As I said to begin with only reply if u have the answer. Is that so difficult to understand.
Your pulling our Chains now you sly fox, you have had several chances of getting the answer then you post a silly reply, I think your just trying to have a laugh at our expense, yes? lol
And as a response, I was silly, I apologise, but you did bite the bait and in my opinion took it a bit too far when you implied that I didn't have a clue what you were on about. I did, just not up on my SP knowledge enough to give you a definite answer, although having since had my knowledge confirmed as correct. I felt that not giving you an answer initially was far more responsible that giving you an answer that was potentially wrong. Maybe I should have just kept my mouth shut and not said anything, who knows, I'm not to be the judge of that one? But I didn't, I thought I'd have a giggle instead.
I'm sorry that not doing as you asked exactly as required of me has offended you.
Before you go away in a huff thinking that I'm some kind of prat who just jumps on people whilst rattling off a load of sarky comments, I just want to let you know that I don't have a problem with you, just your approach sometimes. I still remember you slating Biff's rather nice tray work which I personally thought was uncalled for, so I know this isn't the first time you've been a bit rude.
OK .i'll end it. the answer is....
42. :21:
Thanks for the correct answer ..... I appreciate your help, but now I shall leave, not to return as its too much hassle. Feel free to slag me off as I'm sure you will.
I'm no psychologist, but from reading Pepparz's posts on various threads I would say he probably lacked attention as a child. Daz
Only the manufactures can provide the information. But I think you will find if you care to look that the main failure with impulse testing is the fuses ancillary equipment. I’ve had flash over between fuse bridges due to back EMF caused by breaking an inductive load. We were going through 800A fuses at about six a week. Flashover would take out the riser fuses.
Look in to the construction of a HRC fuse, depending on the fault the ceramic plug formed will correspond to the fault level.
With impulse testing you are looking for the breakdown voltage that results in flashover. Switchboards are type tested. The manufactures couldn’t flash test every board, as they would be ruined.
HiPot testing is standard procedure. Fun when you’re playing with an 11KV board. E54 may correct me on this, it’s been a while since I’ve done it. 27KV to earth sticks in my mind.
DW forget rhino hide, elephant hide was used in old 11KV ACB’s to line the arc shutes.
