Looking for advise and confirmation of my wiring diagram.
Looking to wire a converted garage with 9 LED indoor lights (inside ceiling) and 9 LED out door lights (around the roof).
I want to only add one 2 gang switch, keep them all on one circuit from the consumer unit but two different loops so each switch controls one or other.
Can you provide feedback to my attached image. Thank you.
That appears to be fine. You could just run the supply to the switch and take the outgoing feeds from it.
Assuming this is a dwelling if this is a new circuit from the consumer unit it needs notifying to Building Control under Part P of the Building Regulations. The circuit will also need 30ma RCD protection.
Thanks for the advice. Yes that would make it easier and not having to work in the ceiling.
Yes Building Control have been paid and notified - thanks! I have attached the revised diagram.
