Discuss Install new light fittings (two on same switch) in the Lighting Forum area at ElectriciansForums.net
Lrabbetts
I’m trying to fit new ceiling lights in my living room that operate on the same switch. There are two sets of cables coming out of the ceiling for the first light fitting (I assume one from the switch and one from the other light). The new light fitting looks like this. Please can you tell me how to wire it to get both lights working? At the moment I can only get the first light to work. Thanks for any help. Lisa
TL;DR
Trouble connecting two new light fittings on one switch
Did you take any pictures of the old wiring before removing it?
It’s probably a loop in, loop out lighting circuit. You’ll need to ascertain what are your permanent lives and switched live etc...
Have you got any more pictures?
Reply to Install new light fittings (two on same switch) in the Lighting Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
