Discuss Insulated Torque Wrench/Driver 4 - 10 Nm in the Electrical Tools and Products area at ElectriciansForums.net
Strima
All,
I'm in need to an insualted torque wrench or driver capable of tightening between 4 and 10 Nm.
Any recommendations that won't break the bank.
This is for working on battery strings so need to be insulated.
I'm doing BT power supply swaps. They require all electrical connections to be torqued, marked, then checked and marked gain by the 2nd man. Their preferred bit of kit is a "Cooke set" from Insulated Tools Limited. 10-19mm sockets, adjustable. Pain in the arse to use. Does 4/5 - 25Nm. I find, strangely enough, that my wrist clicks at the appropriate tightness, negating the need for aforementioned tool.
I am! Lower Scotland til December, 1 site closer to home, then who knows next year. Are you familiar with these?
Just binned the contract after an argument over RCD protection for the service sockets. TBH the profit margin was too tight for the amount of sites we were getting from the “customer”....
Reply to Insulated Torque Wrench/Driver 4 - 10 Nm in the Electrical Tools and Products area at ElectriciansForums.net
Hi guys, Hope you're all well!! Due to a recent influx of commercial/light industrial work which has just come in, I am in the market for a...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Long standing issue on my VW Transporter T4. First noticed under 'lockdown'. Battery drains flat if stood more that 3 - 4 days. Industrial spark's...
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
