Good morning all..
My customer has has a Masterchef Deluxe 110 Dual Fuel cooker.
The ovens, grills and warming draw are all electric. The hob is gas, the cooker itself supplies the electrics for the ignition for the gas (i.e it is not plugged in separately.
I changed the consumer unit for an RCBO board. Since then the cooker has started tripping. It did not have RCD protection before.
It is on a 32A RCBO.
It doesn't trip when switched on.
The last time it tripped they were just using the gas burners and the warming draw, however it seems as though it tripped after they had finished using these and they were switched off
Another time it tripped neither of these were being used, and it was just the left hand oven. Again, it tripped when she physically switched the oven off (using the dial, not the main switch)
So it seems to trip with various parts being used.
This tripping cannot be re-enacted. She has tried using the left hand oven, and switching it off does not make it trip again. It seems it only did this once.
IR results for the cable, all the way to the cooker is >999Mohms, L-E, N-E and L-N
IR results on the cooker itself were also high (cant remember what, but many millions of ohms)
They have had 2 cooker engineers out who could find no problems with the cooker. It even tripped in front of one of them.
I have just had a thought. I'm so preoccupied with the cooker, because RCBO's are hardly ever faulty. Maybe just try changing the RCBO? I realise it's not going to be that, but it's worth ruling it out.
Opinions please?
Opinions please?
