Discuss Internet Interference in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
whinmoor
We did a job a couple of weeks ago using a Solar Edge 3500. It's generating as expected but may be having an unexpected side-effect....
Customer has sent the following email:
"I was wondering whether the inverter, or any other part of the system might generate interference with electrical equipment ? We keep having periods of time where our internet connection keeps dropping in and out; needless to say its been alright for the last several hours. I guess its probably the phone line or the router."
Anyone got any experience of PV systems upsetting wireless broadband?
Need more info' to comment.......................
ie. are they are merely using a std ROUTER/MODEM plugged into the phoneline and using std wifi (b/g or n) connection or are they using wifi extenders or mains power through adapters in certain parts of the house ??
I loose my ITV telly channels if it rains since the PV install, as the aerial is in the loft sat behind the panels.
I could faff about installing a new aerial outdoors, but I have found a signal booster was all it needed.
Im going to install a 3 way one in the loft and feed all the tellys from one boosted source.
@MicraShed
That's quite probable, and indeed highly probable as the solar pv panels will act as a faraday cage and hence screen the signals, the installer should have picked that up during the site survey and advised you accordingly.
Reply to Internet Interference in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
Hi all Is anyone aware of the change to solar generation FIT payment contracts for existing installations. (FIT payment scheme closed in 2019)...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
We recently had a solar panel system put it in. The solar batteries were delayed and put in after, at which point it became clear that the CT...
13K
