Hello All
New to this forum so Hi to everyone.
I just finished building a complicated device and I cannot seem to find much help elsewhere to complete the final stage.
I had built a Hydrogen generator powered by 240 volt. The generator requires AC converted to DC for gas production so a bridge rectifier is used. The problem I'm having is I wanted to adjust the voltage so the gas production varies. I purchased a 240 VAC regulator, Live and Neutral in and Positive and Negative to load. Each time when I adjust the voltage, it trips the breaker fitted to the generator. So I replaced it with a 16a Burst Fired Energy Regulator as I wanted a steady flow of Hydrogen Gas. Connected up, tested all the wiring and when I turned on and tested with a screwdriver, there's a very dim light flickering from the test screwdriver. Turned the dial to full but no gas production from Hydrogen generator.
Disconnected regulator and hard wired to the generator and all works well.
Did I bought the wrong type of regulator and would anyone can recommend one, but not too expensive ?
Appreciate any help and thank you.
P.S, Here's the link to my video
