Discuss Is it possible to copy from Sky hd box hdd to my computer hdd in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
J
justanoob
Hi
I am just wondering if someone can plz help i have just been informed from sky that i need a new hd box as mine is faulty but also been informed that i will lose all the stuff on it which some of the stuff is daft progs that i cant get coz not repeated so was just wondering if there is any way i can get the stuff from the hd box hdd to my hdd on my computer cheers and thank you
material on the HDD is encoded as per the firmware on the sky box, you can swap out the HDD, you can also clone it with a standard extrernal HDD case/connector (can be a closed one or a push fit open enclosure) the software on the HDD sits on a small partition on there and there is also operating software in a ROM unit inside the sky box, if your new sky box is a different one, you will need to go into this on your PC, delete the old bootstrap and extra software, then copy over the software (firmware) from the new Hard disk from the new box to the same location, the new box will then pick up and read the hard drive from your old box...or you can copy over the content directly to the new drive and use that...
Reply to Is it possible to copy from Sky hd box hdd to my computer hdd in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
I bouught a Nissan Townstar EV and have found what I consider a theft problem All previous vans I have had allowed the driver to enter and exit...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
I having been trying to make a cart wheel chandelier for my wedding in July like the one in the photo attached. I have 31 lamp holders in mason...
