As the title states really, I see it has the double insulated symbol but seeing as this is a piece of premium Chinesium I am sure the CE mark is fake as well.
I guess a follow up question would be is it safe to use in this state & if not what can be done to make it safe or is it one for the bin?
Does the light fitting need to be double insulated in that location?
I guess not? I just wondered if that because its not double insulated does that mean its not safe? I would presume not.
Is it acceptable that the wiring internally is just basic insulation & this poses no issue because the fitting is earthed & non of that basic insulation is exposed when it is fitted to the ceiling in normal use?
If so great news as I don't have to go shopping for a new light fitting :)
It certainly looks like an item of class 1 equipment with a class 2 symbol on the label.
Strange but not surprising.
I would check the earth continuity to all the exposed metal parts and if that is ok then install it as class 1.
I think the light was originally double insulated, meaning the live and neutrals all went into a small plastic enclosure for connecting to the house.
These are never very big, and the installer thought it easier to replace the supplied connector with 5 way wagos. Doing this would mean it no longer double insulated.
Strangely, however, the earth wire looks original too.
As above , they probably use the same sticky labels in the factory regardless if the light is double insulated or not...
The way this one is wired I would argue it is not double unsulated
I would guess them Ls & Ns that disappear down fitting were originally booted or sleeved, have seen similar.
They the went to a terminal block that wouldn't take loop in - loop out so the DIYer* just stripped it all out.
* that 5way WAGO kinda points to a sparky though.
UK
Is This Light Fitting Double Insulated?
Master Mech,
Dave OCD,
