Gew
Hey engineers!
I'm not an engineer, I know nothing, so I thought I'd ask you about this.
From what I've heard, if you don't have proper ground (a rod) in your house, you should never try to make a "cheap DIY fix" by conencting ground to some radiator or whatever. From what I've heard, the reason for this is that when some appliance in my 230v AC house breaks so that live touches the metal case, and ground trips, then any possible person in the building who happens to hold his or her hand on another radiator (or pipe) in the house will get the same shock as if he or she put two fingers in the outlet, and get electrocuted / die.
So, with this as background, I became very curious when I got to my local commuter train station yesterday, and noticed that a ground cable is attached to a friggin' metal gate on the platform, where all commuter people stands all day. This would mean, that if that ground wire was tripped by a electrical fault, then all the people who would lean against that fence that moment would get a severe shock.
How can this even be legal??
View attachment tåg.mp4
Quite the opposite - it makes things safer.
Path of least resistance.
If current is already flowing directly to the Mass Of Earth, then any other parallel path through something more resistive…. Like a human body… it would be negligible.
Gew
N/A (Vagabond)
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Isn't grounding where people can touch dangerous?
Electrical Engineering Chat
Thread Tags
Gew,
littlespark,
