Discuss Issue with heating controls in the Central Heating Systems area at ElectriciansForums.net
Hi all hope you can help me on this one as heating is not my forteit. Got a communal heating system 6 flats one heating system. 5 flats have heat 1 doesn't. Plumber been to it and says its electrical as no power to the controller. Each flat has it's own controller fed locally from their own board. Each flat has it's own port valve in the plant room boiler and stats etc. There is also a bank of relays but not dont know what they do.Any help will be helpful guys
I'm assuming that the relay circled is for the problem flat
The relay on the left does not look to be used the other relays look to be a common switch to run the heating with each relay being energised from the corresponding flat controls and supply
First off you need to check that when the flat calls for heat that power is getting to the relay
Given that the relay on the left does not appear to be used I would use it as a known good swap for a possible faulty relay
In the absence of any drawings or other information the way I envisage it working each flat will energise one of the relays that will then operate the corresponding motorised valve which will fire the boiler and run the pump
It looks like that relay panel is just to provide supply isolation / separation between each of the flats heating controls and the heating equipment
Reply to Issue with heating controls in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating...
I have 2 Mira dual valve vision showers. The remote control.for the Vision model has been discontinued, so I bought a Mira Platinum dual...
