T
Thirst
I was having a debate with my spark today about methods of joining above ground 3 core (E,L,N) 25mm SWA cable. We need to move the consumer unit and with it the meter tails (fused to 80A). This requires an extension of the tails as it is not possible to completely re-run them.
He said that the best way to do this would be a galv adaptable box, terminate the SWA with external glands, add a 16mm flylead and join L and N with a DP service connector box contained within.
I noted I'd seen resin filled SWA connectors used in the past and whether despite being designed for outdoor use, they could be used in such a situation as this? I know his option is best (ease of access, mechanical protection etc) but I was just wondering whether in terms of regs using such a solution above ground would present a problem?
You can see one being used here for reference:
Is he talking about a 4x4 galv box then connecting the cables and running it on, should be fine as resin filled units are usually used for underground or areas affected by weather.
I cannot see a problem,other than from an aesthetic view-point. Just ensure the particular resin filled connector,is rated for exposure to UV. I do remember that some,had information in their MI,to the effect of being designed for underground use,and not happy in the sunshine.
Your spark's idea,may be the best option.
9"x 6" is about the minimum size of box to realistically joint 25mm. but this would make it a doddle:
don't laugh/i'm just looking for a few designs for my own. . £500 for something that's going to be burnt. sod that. i'm making my own. a few quid for some old timber from the scrap, bit of craft work, couple of handles off the bog door. money saved buys a good pi$$up for my family and mates.
The OP states "2 methods".....there are actually 3....i was lucky enough to view the third,at a rural property,where the joining was conducted,by ....and i kid you not...the conductors joined,by placing opposing ends in a 1" piece of 15mm copper tube,and hammering it flat....the armour was twisted and plaited,like a Korean manicurists hair,and the whole sorry article,was insulated,by sliding a 2 foot piece of 2" lay-flat water hose,over it and placing a jubilee clip,on each end.
Although it lay above the ground,someone had fitted the approved off-cut of roof cladding,over it,to provide an extra level of safety.
Marvellous...
Marvellous...
it bloody worked though????
I like your style....me old ma said,she wants to be eaten by the crows,on a wooden platform,as the Hindus would have done....
Sounded like a long shot,but local authority,Trafford,are having such a performance,over just sorting our green waste bins......i think they may just let us crack on...:rolleyes:
Yep,the "joining" escapade,was one of those many occasions,where there is no point in doing other than a simple head shake. I told him,he was an eejit,he told me i was getting soft....
His landlord is a lifelong pal,so......out it came :)
