And a side note about using blowtorches... make sure your insurance covers you for using them. When I took out mine, I was asked about hot tools, which included blowtorches, and whether I used them. I have a heat gun for shrinking which doesn't fit the hot tool category because it doesn't use flame.
My household insurance allows me to use one of these Master Class Deluxe Gas Kitchen Blow Torch Professional Cooks * Brand New * | eBay - https://www.ebay.co.uk/i/192097300088?chn=ps&dispItem=1&adgroupid=45192390362&rlsatarget=pla-331477173012&abcId=1129006&adtype=pla&merchantid=114891207&poi=&googleloc=1007245&device=c&campaignid=861899495&crdt=0 for my crème bulee. I just take the joint to my house, sorted :rolleyes:
I think I've been sucked into the double post issue! It posts but leaves the post to make you think it hasn't been. I thought you were all just careless!
Yes, it's a pain in the posterior, I've nearly fallen foul of it a few times. You click 'Post Reply', the little spinner widget appears in the top right corner to show it's working and then it just stays there. Maybe the scripts are timing out on the server or something?
(@Dan - Just to let you know, if you didn't already, there is an issue with posting)
This worked for the Apollo 13 crew
The only thing I use a blowtorch is for roasting marshmallows :)
If your happy with the crimped or soldered joint,you could use a short length of plastic pipe to cover the joint,put adaptors on the ends to enable a stuffing gland to act as support
Personally I would be reluctant not to have a box and blank plate for enclosing the joint
Is the damaged cable a switch drop or socket? Sorry just read the opening post, personally I would avoid joining if I could, if you are going to dig a dirty great hole in the wall to repair a cable, I would go the whole hog and replace the entire piece to where you can effect a decent MF joint that wont need burying in the plaster, I appreciate it's allowable, but not my cup of tea I'm afraid.
There are times when there is no alternative, but to 'bury' a crimped or soldered joint. I did such when a chap drilled into cable above socket. Flat roof extension, filled with Celotex with no space for JB.
He was in the process of putting up a picture frame, we could of turned it into a bookshelf, I suppose :eek:
I suppose a small length of conduit with a couple of adaptors and glands on the end would be a good choice.
That's a nice idea and a great tip. Thanks :)
Whereas the hot works section of my insurance does include hot air guns, the only thing it does not include is a soldering iron.
Thanks for acceptance into your forum, quite a few years into retirement now and just pottering around at home. Trying to replace some old wall lights where the connectors were embedded in the plaster and the connection was just twisted wire with a plastic cap pushed on, normal 1950s practice. I found a 2017 thread on the subject on the site and the information was invaluable. Thank you I will be using the site a lot just to keep up with current practice, but I am afraid I probably wont have much to contribute, thanks gentleman you have an excellent site here.
