Discuss Just a fellow customer after a little advice in the UK Electrical Forum area at ElectriciansForums.net
C
CluelessCustomerneedsHELP
Hi all,
I have recently bought a two bed mid terrace Victorian house with a loft room the house is over three floors with a small kitchen and two reception rooms down stairs bathroom upstairs and a double and single room on the next floor and a loft room which we wanted to turn into and extra two rooms. How long should a house like this take to do a basic rewire? With two extras a outside rear light and a waterproof garden socket.
We hire a local family builder to put in new kitchen, bathroom and changes the loft room in to two and he suggested I used his sons for the electrics and the plumbing as needed a new boiler it's been five months with no water, gas, or electric except for a builders socket. The electrician has billed me for 18 days to do a incomplete first fix saying it takes that long the house has been empty for the entire Build. I paid for the materials up front a sum of ÂŁ658.75 and now he wants a further ÂŁ2435. Should it take 18 days to do a basic first fix??? PLEASE I NEED ADVICE!!!!
Hum.... unless you have an agreed spec, and quote from your builders...... its any ones guess.
18 days for a 1st fix sounds OTT for such a small property.
To keep this in perspective, how many sockets, switches, lights, fans etc do you have in total?
If he is trying to preserve the features of the original plaster work , covings, floorboards etc.It could well take a lot longer to do a first fix than a modern house.
The first fix is the most time consuming part of a rewire , particularly in this case as even the loft space will be wired too . So you are really looking at four floors.
It will also depend on the number of circuits that are required for the number of rooms .
PS, I may of misunderstood the loft room . But if access is difficult it may be time consuming.
Hello Ruston, thank you for getting back to me I have recently bought a two bed mid terrace Victorian house with a loft room the house is over three floors with a small kitchen and two reception rooms down stairs bathroom upstairs and a double and single room on the next floor and a loft room which we wanted to turn into and extra two rooms. How long should a house like this take to do a basic rewire? With two extras a outside rear light and a waterproof garden socket.
I would say for the whole rewire it should cost 3500-4500 dependent on the complexity of what you want. But a simple sockets and lights and cooker I imagine on a two up two down with loft/two rooms, sounds like ten days maximum completed. Two people working. So for the complete rewire it should take maximum 20 days. More likely 15 days as its empty. I am being cautious as I dont have a clue apart from your description of the rooms. That would include materials. If I saw the location and house it may be less. But I offer the maximum I imagine it could be.
Hi and welcome to the forum. How many points is there altogether? by points I mean switches, sockets, lights, switched fused spurs, fans, fan isolators, sockets for appliances, etc ? If you add them up and post it up we would be able to give you a pretty accurate average cost and time scale (well as accurate as we can be without actually seeing the job) Cheers
as lee says. a points count would give a fairly accurate estimate. but reading post#3, it looks a bit suspect.. a sensible demand for a first fix would be ÂŁ2000 - ÂŁ2300 including materials (cable, boxes etc.)
Hi lee this was our original list of what we wanted
Full electrical rewire
Second floor bathroom
1.00 1 x light position 1 x switch position non handing 1 x standard 4"extractor fan with timer and isolation switch 1 x shaver socket.
Second floor bedroom.
2.00 1 x light position 1 x switch position 2 x twin socket outlets.
Second floor landing
3.00 1 x light position 1 x switch position in 2 way switching to 1st floor 1 x mains powered smoke detector.
First floor rear bedroom
4.00 1 x light positon 1 x switch position 3 x twin socket outlets.
First floor front bedroom
5.00 1 x light position 2 x switch positions 4 x twin socket outlets.
First floor landing
6.00 1 x light position 1 x switch position top of stairs 1 x 2g switch position bottom stairs to second floor 1 x mains powered smoke detector.
Living room /study
7.00 1 x light position 1 x switch position 3 x twin socket outlets.
Hallway
8.00 1 x light position 2 x switch positions 2 way 1 x mains powered smoke.
Living room
9.00 1 x light position 1 x switch position 4 x twin socket outlets 1 x high level tv socket outlet 2 x gold tip hdmi cables to be installed from tv position to sky box at low level.
Under stairs cupboard
10.00 1 x light position 1 x switch position
Kitchen
11.00 4 x fire rated led down lighter positions 1 x switch position 4 x twin socket outlets 4 x high level s/f/spur positions 4 x low level appliance single socket outlets 1 x 32A cooker supply
Mains position
12.00 1 x metal clad dual rcd consumer unit .
Outside lighting
13.00 1 x front external light position 1 x rear external light positions fittings to be supplied by customer once chosen.
Thank you all for taken the time out of your evenings in answering my question and doubts so ÂŁ3400 for a incomplete first fix with sockets and switches even a shaver socket fan isolate switch missing cut the hole to big for the fan,the sky and tv aerial doesn't work and front and rear light and led spot lights missing from the original list just to mention a few. Do you think he was just maybe taking advantage that we weren't on site all the time because of me having chemotherapy treatment and maybe that I'm disabled? And because of how much I had paid he's dad and brother he could try it on to?
the whole job looks around ÂŁ4500 -ÂŁ5000, complete with relevant certificate and notification.
get him to give you a written quote for the whole job with everything you want specified.
labour only as you said you supplied the material in the OP you would roughly be looking at about ÂŁ3400-ÂŁ3500 that's 1st and 2nd fix and a max time scale of around 14 days for the whole job. With that price and time scale that would be a proper job, no cut corners like clipping cables in chases etc. The 1st fix normally takes longer than the 2nd fix so the electricians invoice/bill could well be proportional but 18 days is over egging it IMO. If it has taken him 18 days because he works extremely slowly he averages out at ÂŁ135 a day based on what hes billing you which is unheard of for a self employed electrician running a reputable business. Maybe he has done it quicker but was shy to state his actually day rate of which should be in the region of ÂŁ200-ÂŁ250 a day in the domestic game.
get him to give you a written quote for the whole job with everything you want specified.[/QUOTE hello Telectrix thank you for the reply first it was ÂŁ2500 all in then he changed his mind and said it was without materials and I had to pay for them ÂŁ658.75 then he said had to pay 20% VAT extra ÂŁ130 on top then we sent me a nasty email saying that he can't finish the job and I'm a hassle to work for.
Reply to Just a fellow customer after a little advice in the UK Electrical Forum area at ElectriciansForums.net
Hello there my fellow electrician. Need some advice about a customer who is being very difficult and annoying. I was called out by the customer...
4K
  • Locked
5K
Hi everyone. I need a little advice please. Several months ago I first fixed and second fixed a timber frame loft conversion ( open plan living...
4K
Hello all. I am in the process of refurbing my kitchen and I have and old redundant T&E cable coming out of the wall above one of the cabinets...
