J
Johnlondon
Hi all,
Simple question - wiring a cooker hood. Is there any reason why I can't take the supply from the cooker outlet? outlet, not isolator.
If I recall, there is a reg about matching the cable size for the hood with the cooker cable size if I am taking the supply from there if it's longer than 3m. If less than 3m I can determine my own size. Anyone able to give me the reg number?
thanks all
if you fit a FCU with a 3A or 5A fuse after the cooker outlet, then wire to hood in 1.0mm or 1.5mm then you're OK.
