Discuss Knipex installation pliers in the Electrical Tools and Products area at ElectriciansForums.net
I have a set of these, I think they're really good. Only thing I don't like is when your second fixing t&e, i use the method of using the earth to tear the sheath back (probably get hassle from the older guys about this method hahaha), which with snips is easy, small snip end on to the t&e and pull the earth out. These pliers won't allow you to do it really, you can mess around and try to use the shears part to do it but it's not the same. Great go to tool for anything else though.
Amd definatly get the sprung ones! Using the stripping notches with the sprung feature is brilliant, fast, and no fear of damage to the conductors. Same when trying to get conductors into an accessory, the end of the pliers allows you to grip the conductor with out risk of damage to the insulation, recently used that feature to get 6mm2 into an awkward oven termination.
Apart from my t&e second fix gripe, I would recommend these! Especially since they're coming down I price now too, were around ÂŁ50 when I first saw them around a year ago.
Yes I was taught to use the earth wire ripping method too which I usually do w/o problems, although I believe the "official" tool to use is a knife!? Anyway, have ordered the installation pliers as I found them for ÂŁ35 on eBay, so I'll see how I get on with them
what other way is there to strip T and E anyway??
Snip into the end and pull each half away from the other
Snip into the end and pull the earth.
Slide a knife along the length of the cable next to the earth.
The knife method is the only way I've found that works well on the bigger sizes, especially with LSF varieties
I tend to just pull the earth to prevent any damage by accident..but thanks for the other ways will come in hady :smiley2:
Cut down with diagonal cutters between CPC and a live conductor, pull apart sheath with fingers, trim sheath with cutters. That's how I always do it.
I'm not at all a fan of pulling the CPC through the sheath or sliding a knife down against the CPC.
That's the way I was taught, and normally use.
But the bigger stuff, especially LSF crap, is a bit hard to do that with. So I'll either knife it, or score the sheath and pull the earth through the score mark
Totally agree with that horrible tough stuff, a knife is the only way forward.
The pulling apart method usually serves me OK with PVC T&E, but the knife has to come out for 10mm and up. Thankfully I don't generally have much to do with LSF, LSOH, or 10mm plus PVC in my day to day.
OK so how do you guys strip flex, i usually try and score it with sharp snips then bend it until it rips...i heard other people nibbling bit by bit off until it can be bent to rip...any easier ways??
For flex stripping I use a brilliant little tool I've had for over 25years, it cost less than a fiver and always gives faultless jacket stripping of flex of all sizes, once you get used to it. . You open it up, push the flex thru then rotate the tool several times, depending upon the flex size. It scores the jacket cleanly and without nicking the conductors, you then remove from thr tool then bend the flex to snap off the remains bit of jacket, then pull it off.
They do a similar one on the TLC catalogue called cyclops GP5206. ÂŁ8.99.
Reply to Knipex installation pliers in the Electrical Tools and Products area at ElectriciansForums.net
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Hi All. I'm seeking some advice. About trousers/dungarees. I've secured work experience with a local firm, doing two days a week at present with...
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
