littlespark
Staff member
Supporter
Patron
A good customer of mine has bought a brand new house, with existing outside sockets of the Lap brand, fitted by the builders, I don't know who did the electrical work.
The external sockets (3 of) are wired on the rfc… He would like another socket at the bottom of the garden for his "beer shed" fridge, and maybe another one. Asked for them to match the Lap ones on the house.
The question is, do Lap do an external 13A switch fuse? I only see sockets and lightswitches on Screwfix. (is Screwfix the only supplier of Lap?)
Just typing this... I think I've got a solution. Take the external socket off the rfc, install a SFCU inside and have everything outside as a radial off it.
The Lap stuff looks really nice but I have regretted installing it in the past. The switches on the sockets have a tendency to just stop working....usually they just get stuck in the 'ON' position. I've also had a couple that have stopped accepting plugs properly...in that they will only go half way in, actually quite dangerous really.
I actually have a few spares which I am keeping for a couple of customers when I get the inevitable phone call.
As far as availability....it is all on the Screwfix website, as far as I know it is their own make.
I had a LAP SFCU which did not turn off...:) a very good reminder to rely on checking safe isolation,using proper means...and not just a manufacturer's promise :rolleyes:
Have you told the customer that you and others have had problems with Lap items malfunctioning in the past?
See what he says. If he insists on you installing something that you are not happy with then maybe you could put something in the quote, to the affects of: If the Lap item fails within the warranty period you will replace the part, but the customer has to pay you for the time. Just a thought..
I think the LAP weatherproof sockets seem pretty good. Well made, robust and at present no failures. Sorry for not answering the question though.
If the existing external socket is on the ring then surely you could spur from it for another socket?
Let the customer purchase it and tell him you are supplying no warranty with it as it is the single worst brand I have ever seen or installed it is such poor quality I'm surprised it even passes to be on the market
Funnily enough I've had no issues at all with Lap, but BG accessories is another story. IMO they've gone downhill in recent years, even the 'premium' Nexus stuff. Although the external sockets are good.
Thanks for replies.
Spur from existing outside socket was feasible as it would be a spur from the ring, but customer now wants a second socket further along the bottom of the garden. Can’t have a spur off a spur without the FCU.
Already thought of replacing a single socket plate with an FCU inside the external rated box, but it’s the wrong shape. Not standard square shape.
I think I’ll suggest to customer turning the outside socket into a spur and fitting an FCU inside. Then just link from socket to socket to socket as a radial. I am assuming there’s a double socket inside and enough space to add a box and FCU.
