Possibly induced voltage, if it is it can be sorted by fitting a contact suppresser. Did you fit the lights?
call 555-2368
If all the wiring is correct, then induced voltage is the most likely culprit. Did you test the circuit prior to switching it on? Are the lights on a 2way?
Induced voltage....
Or could be the new type of LED lamp that just wont go out, you know like the birthday candles that wont go out...its the same company that make them...
So we're down to 4 possibilities, induced voltage, bad wiring, trick LED's and ghosts. Or maybe even solar flares? Or radiation from the plutonium hidden in the ceiling?
