J
jelswood
I've just bought GU 5.3 led lamps to replace halogens but when the light is switched on they flash and turn off. Please help??
When they flash they don't blow, I can switch the light on and off repeatedly and the flash every time
it they are connected to 12V transformers, that's the problem. you need the correct type drivers.
You need unniterrupted power supplies for LEDs, and as Tel above mentioned it needs to be a driver and not a transformer.
that's why i always rip out the transformers and fit GU10 LEDs. less hassle, less to go wrong, no conflict of equipment.
It's a shame that the packaging says nothing about the transformers! Clearly wouldn't have bought them otherwise. What drivers do you suggest?
Pop into your local wholesaler with a lamp and they will advise you, they are around a fiver each ish I suspect from memory
If the lamps are specified at 12VDC then 12VDC transformers should be OK. Just remember they will have been specced for the loading of halogens lamps. Now that you have gone to LEDs you will be operating below the minimum loading of the transformer, and if it is an electronic transformer it will shut down. Check the min. rating. Daz
