DeanoRN
Trainee
good evening ladies and gentlemen
Just a quick question, my aunt has asked
Me since she’s having her kitchen redone can I fit LED lights under her cabinets,
It’s not somthing I have done before Or even seen done so I was just wondering if it’s a tricky job.
I was thinking I could do the job for experience and a get a fully competent electrician to sign it off.
Obviously I don’t want to takle a job that’s out of my league I have been on. Various rewires and remedial work but as I said never anything like this.
Thanks for any help or tips
Dean
Thanks for the reply telectrix, so they are
Not normally looped onto the normal lighting curcuit with the transformer? Sorry for the daft questions just never seen them installed or
Anything.
Dean
you fit the driver and wiring under base units. just need access to a socket.
You can also use these:-
8mm Low Profile LED Tape Kit - Weatherproof IP65 - Natural White - 5 Mtrs - https://www.tlc-direct.co.uk/Products/SK153728.html
240v to 12v LED Driver - 12 Watt - https://www.tlc-direct.co.uk/Products/LALED12DRV12.html
Aluminium Profiles for Led Tape - Short Crown - 18mm x 9mm x 1m - https://www.tlc-direct.co.uk/Products/SK156807.html
The tapes are available in various colours, the extrusion is available in various profiles and the drivers are available in two sizes.
I've used the tapes on a couple of occasions, the last one I used these drivers and extrusion and it worked out really well. Doing another kitchen using them on Friday.
Hi sparkychick, thanks for the reply, so it seems to me like it's a fairly job, and its all mostly plug and play?
The tape comes with a suitable power supply which plugs into a pre-terminated connector on the tape.
The issue is, the power supply requires a plug so isn't always suitable and if you do things like turn corners you either need to use special connectors (which I don't believe fit in the extrusion) or cut the tape and solder new connections on to it.
The job I'm doing on Friday, there are two sections. One turns a corner and one is a long straight section which is separated from the other. So I'm using one of those drivers for each section, dropping a two core cable down a gap in the units and putting the drivers on the top of the cabinets out the way.
Ahh cool I see so you just hide the driver under the cupboard or someone out of sight, and what about putting it on a switch to turn it off and on? How is thst achieved?
Regards
Dean
Regards
Dean
best buy a set with a remote. then the customer can switch on/off and change colours, sequencing etc.
Regards
Dean
Normally, you would have a switched mains supply. I've installed switched supplies for cabinet lighting when rewiring kitchens and these I've used the tape, they have been retrofit applications, so there is a switched supply available on the cupboards.
Normal lighting circuit arrangements basically.
So when you are fitting them into the mains supply the job is alot harder than just the simple plug and play, i've watched some videos that they cut the end of the plug and just attached it to the mains supply but it didn't mention about using a switch to control, i'm probably over thinking it but when i've installed LED downlights with a transformer we used 3 wagos to connect all the terminations is this the same principle with the led strips, again sorry for these daft questions
regards
Deano
How you connect them to the mains depends on where they are being installed, how they are being installed and what's available.
I used some of that tape under the bar at a local hotel... in that case, the connectors and power supply that come with the tape were ideal. It was one long run of tape, stuck directly to the underside of the bar. The power connector simply got pushed through a hole in the bar and was connected to the wall wart which was plugged in under the bar.
In the kitchens, it's different... the terminations that are pre-attached to the tape won't go through the end caps of the extrusion so I normally cut the tape at the first cut point and solder on cable. When turning a corner, I either solder on connections at the one end and then turn the corner with cable into another section, or I supply both tapes at the corner.
The drivers require a connection to LN only for the mains supply, so you can use a bit of two core cable to connect them to a plug top (3A fuse) or you can connect them directly to a suitable feed (by suitable I mean fused down to 3A). Any switching should be done on the mains side.
If I remember today and time allows, I'll take some pics of the install I'm doing.
Thanks a lot much appreciated:)
So, the installation I did this morning....
The lights are supplied from a switched fused connection unit. The load side of this appears out of the wall on top of the cabinets in two locations. This is the first:-
The white two core cable on the right, dropped down in the gap to supply the existing lighting. This was cut back and terminated in the driver.
Mains in at the top, 12v DC constant voltage out the bottom. Notice the use of bootlace ferrules to protect the stranded conductors. If the terminals have flat springs in them, you don't need the ferrules. But these particular drives, it's just screws so I ferruled them.
The DC side is wired with some basic speaker cable, plenty big enough for the low power requirements of the LEDs. It drops down in the gap and is pinned under the cabinets where it is routed to the corner. There it splits. All connections on the DC side are soldered, and where the wire is split, it's heatshrink, adhesive lined. Small over each conductor and then a larger overall covering.
Pre-heat shrink testing:-
Post shrinking:-
Internally, where the conductors are soldered on to the tape, they are wrapped in some PVC tape just to minimise the chances of a short on the extrusion. I didn't heat shrink them because the shrink I have is probably a bit too strong and I didn't want to squish the tape.
And here is one of the strips ready to go.
Fitting is simply a matter of mounting the clips supplied with the extrusion and clipping the strips into place.
Hope that helps.
Post shrinking:-
Hope that helps.
Hi sparkychick,
ye this is great it helps so much, i will be giving this ago on Monday. you have really cleared it up for me cheers :)
