R
RedSnedd1903
Hi everyone. First time poster here so go easy. I have a lighting circuit on an installation I'm working on that is giving me some grief. There are 50 x 4W gu10 LEDs on one switch and it keeps tripping the 6A mcb. The total load of the lamps is not even 1 amp. There are other lights on the circuit but the total load comes to about 5A. Insulation resistance check on both switch wires are both clear>299. It happens every 2nd or 3rd time that the Led D/lts are switched on. Even when all other lights on the circuit are switched off. I've tried replacing the circuit breaker but still the same happens. Has anyone else had any problems like this.
cheers
Al
cheers
Al
