L
LAMY
Hi just enquiring if anyone has had problems with photo cells controlling led lights.On a recent job i connected two 30w led floods and an over sign led strip to switch via a photo cell,when first powered up lights came on i assumed this was just the photo cell kicking in on initial power up,but lights did not turn off i checked wiring and investigated a bit and found if you turned power on with photo cell connected lights stayed on if you disconnected switchwire from photo cell at adaptable box then turned on, lights did not come on and then you could reconnect switch wire and all seems to work ie if you cover photo cell lights come on if you remove cover lights go off.My concern is if power to lights trips for any reason, when power is reinstated lights will stay on, im wondering if there is a special photo cell for led lighting.Thanks in advance any info regarding odd things relating to led lighting control would be appreciated.
