Discuss LED Narrow Beam spotlight? in the UK Electrical Forum area at ElectriciansForums.net
S
slide
Hope someone can help
I'm looking for narrow beam LED spotlights for replacement into Gu10 or MR16 fittings
Osram do a product called 'Halospot' which has a beam angle of 8 degrees, though I'm struggling to find an LED equivalent. Dont wanna use halogens as they'll be fitted at high level.
Any ideas?
Cheers
You can buy separate lenses for TLC's ledlite range down to 25 degree,can't think of any doing it tighter than that off the top of my head
If you are focusing on to an object then the old "ultra bright" LED lamps have an angle of about 13 degrees but they are not very bright. various sellers still stock them they are the ones that have the LED cluster. usually about 1 -2 watts.
These are the 13 deg ones from toolstation.
Reply to LED Narrow Beam spotlight? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'd like to replace some MR16 halogen fittings on an exposed wooden beam to new GU10 fittings which I will be fitting led lamps into. The...
Does anyone have a recommendation - preferably without needing a second mortgage - for some outdoor spotlights ? I've tried a number of options...
H
Okay, this is probably going to be a really stupid question, but I'm hoping someone can point out my error. We have spotlights all over our...
12K
Lisa P
L
Deltalight, Eutrac, LEDS-C4, PSM, SLV and WOFI as well lamps and lightbulbs from Osram, Syvania, Megaman and FN. Lighting Design Toplightco is a...
Has anyone fitted the GU10 firerated downlighters supplied by Avantech? Come from a trading co called red arrow.. not prefitted lamps but fit your...
