Discuss Light Switch Installation in the DIY Electrical Advice area at ElectriciansForums.net
The light already installed can be controlled from the top and the bottom of the stairs and I was advised to buy a 1 gang 2 way switch. The old light switch has 4 terminals but the new one only has 3. My question is where the earth goes as there is no terminal for it on the switch or inside the back box.
Disconnect the short earth tail from the terminal in the back box, leaving the earth wire from the incoming cable still connected.
Hi Thanks for your reply.
Do you mean I should leave the earth in the u shape where it is and remove the other earth wire that is hanging loose completely
Reply to Light Switch Installation in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
