Discuss Light wiring help required in the Lighting Forum area at ElectriciansForums.net
RockyS
Hi
I’m in the process of swapping over a fluorescent light to an LED light in my fathers garage,and stupidly forgot to take a photo of the wiring before I disconnected the original light?.
I’m wiring it in through a connector block as he wants the option of maybe adding another one at a later date. My question is could somebody please help me regarding connecting the wires?
I’ve attached some photos which I hope will help
Which coloured wires need to be connected together? I should add it’s a one way switch in the garage. A big thanks in anticipation
Craig
The blue with the brown sleeve is live, blue is neutral the green/yellow are earths. What do you mean connecting by connector block.
what he said^^^^^. and the 2 browns stay as they are, not connected to the light itself. make sure the earths are connected together. (probably a terminal marked E in the light for these).
Is that 32amp rated joint box your connection block?
and...Will you have access to it on completion?
needs replacing with a smaller one. or even better a quickwire . it's accessible surface mountedon the timber.
The surface clipping needs tidying up too.
agreed . the clip nails should be below the lower cable and above the upper cable. they'e cables, not railway tracks.
Reply to Light wiring help required in the Lighting Forum area at ElectriciansForums.net
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
Hi can anyone help me with this light switch? Photos of how it was wired to old switch but new switch is different with different names. I’m...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
