Discuss Lighting circuit, no earth. in the UK Electrical Forum area at ElectriciansForums.net
It's a sad fact that, unfortunately, at least 50% of the great British public out there are imbeciles. You just have to grit your teeth and get on with it. It's not just in the world of electric's, it's just generally.
Blimey that high. Well, your probably right. Case in point, just did a favour for someone in "desperate trouble", went to a so called emergency job, and gave them a bill for a very reasonable £50. They told me they had "left an envelope" with next door. When I went to pick it up, it had, wait for it, £49 quid in it. What do you do???? unbelievable.
Went to a little job before to replace 2 light fittings - both were metal, and on further inspection i saw the lighting circuit had no cpc.
I told the customer it wouldn't be right to fit them - he didn't like that... a selection of things he said:
" These regulations you speak about aren't there to make people like me safe, but to make you boys rich..."
" I'll get someone who knows what they're doing to do it..."
"Its all a load of bullshht..."
Just can't help some people can you! :90:
There are plenty of metal light fittings out there on the market that have been manufactured to Class 2 standards. Don't assume that all metal lighting fittings are Class 1 and require a CPC connection.... I'm not saying in this instance that these fitting weren't Class 1, they probably were.
I know of at least two manufactures that specialise in the production of Class 2 metal fittings...
Reply to Lighting circuit, no earth. in the UK Electrical Forum area at ElectriciansForums.net
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
Hi, Just interested in learning what others do when faced with an old lighting installation where there is no earth and you’re installing a metal...
Hi, I do basic electrical DIY like changing light fittings and have got a light to put up that only has a fly earth and no flex earth (see pic)...
