Discuss Lighting fault plz help!!! in the UK Electrical Forum area at ElectriciansForums.net
I wouldn't rule out faulty mcb but in my experience its rare, think ive had 2 in 20yrs, a damaged cable can have low insulation value or damp in joint somewhere or even a choke in fitting on its way out ... these are examples of faults that can cause intermittent tripping and even let you reset the mcb. Id do a full test throughout circuit at all outlets as oppose to wasting money and time replacing each fitting.
Ive just given a few reasons its really for you to test and trace now... other examples are a trapped cable that faults as someone walks on a certain floorboard, or a joint getting wet when it rains, flourescent control gear could have a faulty choke that shorts only when it gets hot enough so wont trip if on a short duration, seriously the causes are plentiful and they are all shots in the dark, if you have another mcb in board same rating then swap them over this will tell you if mcb is suspect but with regards to telling you whats causing it ..we cant, if i get this fault myself i check with times, dates weather etc see if anything jumps out but other than visual on o/s lights etc id carry out the appropriate tests or you could be going back and forward a long time.
Any recent works on floorboards/loft work/plumbing etc? Are all cable terminations correct and tight? Signs of overheating or other damage to switches etc? The list could get endless.
Wow never seen so many clever dicks!!! But Many thanks to the ones mature enough to reply to me properly i will take on all your advice i was just asking for simple advice from some of you more experienced electricians.
Reply to Lighting fault plz help!!! in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
