Discuss lighting issue in the UK Electrical Forum area at ElectriciansForums.net
I have a table lamp with inbuilt touch sensitive switching/dimmer. It comes on every time the computer is turned on and every time the scanner is used, they are in the same room. Earthing is good (PME). I have got used to turning it off, one two or three taps depending on how bright it is. I have always assumed it is transients much harder to get rid off than ghosts. One day I will get around to turning it off at the socket.
Why put off until tomorrow what you can put off 'till next week.
I think he means that it shouldn't be too old, and be fit for purpose. Perfectly reasonable.
In the current climate of austerity, i can't afford to change my old cover, I may never be able to!!!
How often does tel get a new bed-cover for himself? and how can he afford it??
Touch switches that replace ordinary plate switches rarely use a neutral connection. As a consequence the electronics is often prone to false triggering by mains bourne transients or strong radiated RFI. There are a couple of things you can do to minimise this effect:- 1) Ensure the CPC is connected to the metal back-box. 2) Connect a mains rated CR (typically 0.1uF in series with 100Ω) snubber across the switch terminals. If the touch switch is currently mounted in a plastic cavity wall box, try changing the standard plastic box for the less common foil lined or metal type which has a CPC termination connected to the foil.
Reply to lighting issue in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Kitchen led lights have all of a sudden dimmed by about 30% no dimmer in the system. There are 2 switches for this set of lights. Regardless of...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
