Discuss Lights only come on when main light is off.. in the UK Electrical Forum area at ElectriciansForums.net
T
the glory years
Hi
I'm new here so be gentle. I have a reasonable knowledge of electrics and did an essential electrics course and my 17th Ed a few years ago. I have just tried to add 2 new lights from a feed from a bedroom lighting rose to 2 extra LED mains voltage lights off a seperate switch. After carefully locking off the mcb etc and wiring as per loop in, switch and loop out to 2nd light etc, they would only come on (via the pull switch )when the main bedroom light was turned off...? I can't work out why..? I know it must be obvious but it's been a while since I did any work (I'm looking to get some shadowing or trainee work as well) Anyone help ?
p.s the main light did have a low voltage lamp in it if that helps...
sounds as if you,ve taken the N from a switched L, instead of a N.
Oh right thanks....in the ceiling rose I've fed from ? So basically swap them round...? I was in a rush and couldn#t get me head round it etc..
Are there any other diagrams on here I can quickly refer to....with regard to what I was doing ?
just check your connections in the fitting you've taken the feed from. should be obvious once you look.
I know...just one of those I expect that the longer I looked the less I could see !!! That's all it's likely to be I guess ? Thanks for your help though.
The bedroom light you came off from was it last on the circuit? (old colours, forget earths) IE. two reds, two blacks?
if so you may have picked up off the perment feed "Reds", and switch line black. as telectrix says check the conections, it will be ovious when you see it :)
Yes it was the last in the circuit..ie 2 reds 2 blacks. I fed from the red live and then the neutral off the neutral bar and earth to connector etc....?
My bet is the neutral is really the bedroom switch line, try swopping the neutral across over to the other black...
Yeah could be..didn't think of that...Going back Saturday so I'll test them and give that a try. That's really all it can be I guess....?:crazy:
:crazy:
Is it really wise to be just 'swapping cables round' ??
Sry Glory years, should have made a complete list.
Isolate supply
using an aproprate Ohm Meter, test between Reds (third plate) and one black
operate the switch and see if you get continuity. (lamp removed)
then do the same on the other black.
one of the blacks will show continuity when the switch is operated..
this is the switch line for that light and is not the neutral
:) Joking aside you are right mickys86 sometimes what you would just do on site really needs a thought or two when typing here..
swapping wires round will have one of three results:-
1. it works. 2. it don't work. 3. it goes bang.
i vote for no.3.
Hi
your switching a feed
it was the thought of messing about rewiring fuses that mase us get it right first time
try using that excuse in a court of law if your house burns down.
you should never be in a rush when working on electrical circuits. get an electrician in to do the job properly who will have made plenty of time to do the job without being in a rush and making the job safe
I'm fine, thanks anyhow. I know all of that, I know the problem now and I DO have enough knowledge to have left it all safely disconnected. I appreciate your concern though.
Reply to Lights only come on when main light is off.. in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
