Discuss Load Testing in the UK Electrical Forum area at ElectriciansForums.net
Unity power factor assumed?
Absolutely. But for domestic, where most of the big loads are resistive, it's a reasonable assumption.
And if what you're interested in is loading of cables and overcurrent protection, it's the current that matters (which is what's being measured).
Obviously, for a more comprehensive picture, then a 'proper' monitor with voltage connections, showing power factor, VA, VAR, etc., will be required, but for many purposes, a cheap 'current only' device will do the job.
Yes, as you say, current matters in this case. I was just questioning the assumption that it was all unity power factor.
Reply to Load Testing in the UK Electrical Forum area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
