N
nigelyardley
Hi,
Looking for a single 240v DIM mounted relay, with 2 inputs and 2 outputs.
Under normal conditions, a constant 240v input from the mains (In1) only activates an output (out1).
However when a switched 240v input is triggered (In2) I need the relay to stop Out1, and power Out2.
During this time however, as In1 is a constant feed this will still be the case, but Out1 must not be powered whilst Out2 is.
Once the input from In2 has stopped, the relay should switch back to Out1 from Out2
Any help would be much appreciated on this
Nigel
Hi Tony,
Thanks for the quick reply. When In2 is powered will it completely stop Out1 and just use Out2 using this relay then?
Also any pointers on where I can get a wiring diagram detailing which pins to connect to what??
Thanks again
Pin 1 Common 1
Pin 2 Coil 1 (L)
Pin 3 NC 1
Pin 4 NO 1
Pin 5 NO 2
Pin 6 NC 2
Pin 7 Coil 2 (N)
Pin 8 Common 2
I/P 2 will cut I/P 1
Just to confirm as i'm still not 100% clear
L1 = Always on feed
N1
L2 = Switched feed
N2
Vent L1 = Speed 1
Vent L2 = Speed 2
So I would connect which to which pin?
Pin 1 Common 1 =
Pin 2 Coil 1 (L) =
Pin 3 NC 1 =
Pin 4 NO 1 =
Pin 5 NO 2 =
Pin 6 NC 2 =
Pin 7 Coil 2 (N) =
Pin 8 Common 2 =
Thanks again
