diynot
Hi. Just wanting to lower the height of this double socket. Just curious to know why one of the earth's has been cut. Is it Ok when lowering the socket and using a new plastic double socket to copy this exactly? Thanks.
I think that was auto-correct from "When you re terminate lower, you should have the CPC in separate sleeving, and not twisted at all"When you re terminate lower, you should have the docs in separate sleeving, and not twisted at all.
Ok. Thank you. Very much appreciated.Electrical sockets or switches should be fitted at a safe distance (it is recommended at least 30cm horizontally) from a sink to avoid the chance of water coming into contact with electricity. Sockets should also be easily accessible. If appliances such as fridges, dishwashers, and washing machines are fitted under worktops, getting to sockets may be difficult. Ideally, these appliances should be controlled by a switched fuse connection unit mounted above the worktop where you can reach it easily. FCU above with Socket below the countertop.
Ok thanks. Seperate sleeving is easy, don't know why this wasn't done years ago when originally fixed. Thanks.Looks to me like UNG suggests.
The left hand cpc goes over to the right with a short piece of sleeving. Both are then twisted together, and use the same sleeving up to socket.
You can see two cores twisted together at the terminal.
Because the integrity of the earth wire is the most important of all, and when the installation was done, twisting the wires together was seen as a better way of ensuring this than relying on a terminal clamp in the fitting.Ok thanks. Seperate sleeving is easy, don't know why this wasn't done years ago when originally fixed. Thanks.
Right, thanks for the explanation.Because the integrity of the earth wire is the most important of all, and when the installation was done, twisting the wires together was seen as a better way of ensuring this than relying on a terminal clamp in the fitting.
There was no requirement back then for a lot of the testing that is required now.
